Replaced shuttle valves and performed ABS mod - 3 amigos still on
Old 06-08-2015, 09:30 AM
LA_Disco2's Avatar
I honestly don't know ralphobell. The technician who performed the work is a fellow D2 owner but I'm not sure which scanner he was using. I was hoping someone had encountered the same problem and might know what the issue was.
Old 06-08-2015, 09:35 AM
drowssap's Avatar
i had a similar problem my hawkeye would not allow me to clear the codes, turned out the conversion was done wrong and had a loose / bad connection
Old 06-08-2015, 09:45 AM
LA_Disco2's Avatar
The ground was double-checked and the connection was soldered. Any chance we wired up the wrong wire on the ABS module?
Old 06-08-2015, 10:25 AM
mln01's Avatar
In addition to completing the wiring bypass did you also check resistance across the switches as specified in Josh's write-up? If the switches were already bad the bypass alone will not correct that problem. EDIT --- Never mind; I overlooked the fact that the OP said the switches were replaced. Nonetheless, perhaps it would be worth testing the switches anyway to see if they were perhaps bad right out of the box. Unlikely I know.
Old 06-08-2015, 09:36 PM
Joemamma1954's Avatar
1 should be to yellow/green wire. The other to ground. Doesn't matter which wire is grounded and which is hooked to yellow/green wire.
Old 06-08-2015, 09:54 PM
If they cut the yellow/green wire to splice into, they may have spliced into the wrong end. It should not go back into the abs, but to the ecm.
Old 06-08-2015, 10:32 PM
here is picture of how i did mine. I did not cut mine, i just used a posilock tap, and tapped into the yellow/green wire, and did the same on the ground wire which is the thick black wire coming out of the abs, below the larger connector.
Replaced shuttle valves and performed ABS mod - 3 amigos still on-img_3807.jpg
Roont (10-29-2023)
Old 06-08-2015, 10:38 PM
I personally do not like cutting oem wire harnesses unless i have to. The taps i prefer are these:
Amazon.com: Lockitt Posi-Tap 6pc pack #605/6 16-18 awg Blue: Automotive Amazon.com: Lockitt Posi-Tap 6pc pack #605/6 16-18 awg Blue: Automotive
Let me know what you find out.
Old 06-08-2015, 11:59 PM
cappedup's Avatar
That's a good outside bet.
Old 06-11-2015, 12:58 PM
LA_Disco2's Avatar
Joemamma1954 for the win! Thanks man, that did the trick. It was spliced into the end going back to the ABS module.
You can collect your cold beer the next time you are in Mobile, Alabama.
Quick Reply: Replaced shuttle valves and performed ABS mod - 3 amigos still on
