Replacement fuel pump - no NAS EVAP sensor
Old Sep 20, 2017 | 01:09 PM
Baylink's Avatar
Default Replacement fuel pump - no NAS EVAP sensor
I've just bought a replacement fuel pump from an eBay seller whose fitment guide said it was a match for my 2000 DII... but on arrival it turns out not to have the ODB evap sensor or a hole for it, so we have a hose and a wire to dispose of...
Which is a better solution: connect the sensor and just lay it in the well of the mount? Or don't connect it? Which will **** off the ECU less?
I bet on "connect it"; was I wrong?
Old Sep 20, 2017 | 01:58 PM
Jeff Blake's Avatar
There are two different fuel pump part numbers. Simplest way to deduce it is: with SAI = WFX101060 and without SAI = WFX101070
Sounds like you don't have SAI and received WFX101060. I would recommend getting the right part. You'll probably get an error code if you don't hook up that sensor.
Old Sep 21, 2017 | 07:38 AM
Baylink's Avatar
I'm expecting it to throw codes, but those are nothing new on my truck. :-}
My question is -- since it's terribly impractical for me to push it from 3 weeks down into 4 -- is it actually going to *affect the engine running* either way, and which one worse?
My intuition is that it won't, and the ECU will just be annoyed at me.
Old Sep 21, 2017 | 09:33 AM
OverRover's Avatar
" My intuition is that it won't, and the ECU will just be annoyed at me. "
That's optimistic at best. IMHO, and as Jeff said get the right pump. You will be glad you did in the end.
Or you could give the wrong pump a go, but just remember to have some Tequila standing by to numb the pain. Good Luck!
Old Sep 21, 2017 | 04:47 PM
RoverMasterTech's Avatar
drill a hole in the top of the pump and put it in.
Old Sep 21, 2017 | 06:46 PM
jastutte's Avatar
care to elaborate?
pwaltrip
Nov 20, 2012 07:12 PM
dev99disco
Sep 18, 2010 12:38 AM
mcleoddude
Nov 1, 2009 04:38 PM
mcleoddude
Oct 31, 2009 06:07 PM
gdtna
Defender
Jul 11, 2009 04:38 PM
