Replacement radiator
Old 06-22-2012, 03:05 PM
ebg18t's Avatar
Default Replacement radiator
I have looking online and there is a wide range of prices.
Anyone recently purchased a radiator? If so from where and how much?
I left a MSG for PTshram and paul grant. Waiting to hear back from them.
Old 06-22-2012, 03:15 PM
Paul Grant won't be able to help you, he does not deal with new parts and you don't want to buy a used one.
A decent one should run you around $300 plus a t/stat, new pressure cap and coolant.
Old 06-22-2012, 03:31 PM
kc disco guy's Avatar
Banned
I have a used radiator I was considering having boiled and keeping for a spare, Mike is this worth the cost or should I just scrap it?
Old 06-22-2012, 04:06 PM
IMHO for a D2, nope. D1 - yes, thicker rad, coper and brass, pricey.
Old 06-22-2012, 04:15 PM
Bkreutz's Avatar
I don't know of any shops that will attempt a repair on a composite (plastic and aluminum) radiator. The plastic gets brittle with age. I just replaced mine with one I got from British Pacific and it fit like an OE (I was kind of concerned, I've had problems with non OE radiators not fitting without "adjustments", but this one had no such problems).
Old 06-22-2012, 05:06 PM
The answer is no, the plastic is too brittle and the veins are so small, they don't clean out, throw the old one away.
Old 06-22-2012, 05:47 PM
antichrist's Avatar
You can get a few bucks for the old one at a metal recyclers.
Old 06-22-2012, 05:53 PM
ebg18t's Avatar
Looks like brittish pacific sells the AllMakes version.
Old 06-22-2012, 06:26 PM
Try not to use the All Makes, there is very little that they make that is an equal, in quality to a factory unit. Call P.T. Schram, if I am not mistaken, he gets his right out of the UK.
Old 06-22-2012, 07:58 PM
Banned
Thank you all for your input.
Quick Reply: Replacement radiator
