Replacing Battery Terminals
Old Jun 7, 2016 | 04:42 AM
mln01's Avatar
Originally Posted by Jeff Blake
Shims don't solve my need to run another positive wire though. Not a fan of 'hacks' either.
Lopping off the factory terminals is a hack.
Do you see the hole in the top of the POS terminal? It's threaded (M6 I think). Buy an appropriately-sized bolt and washer and attach the wire for your new circuit there. No cutting. No expensive crimper needed. That's how the cable for my winch is attached. Remember the KISS principle.
Now for my hack. I too had loose battery terminals. For years I used my Vise Grips to deform them, that is, make them slightly not round. Worked pretty well. But a few months ago when I installed the current battery I tried something else. I drilled a small hole in between the terminal and the battery post and then installed a small screw as a shim. Did it on both the POS and the NEG. The terminals don't vibrate loose any more. Yes it's a hack, but far short of cutting off the factory terminal.
Old Jun 7, 2016 | 05:44 AM
batard's Avatar
Just my opinion, but if you're going to hack it this much, it's perfectly reasonable to instead replace the factory terminal, which isn't difficult or dangerous. I'm not criticizing your method because it obviously works.
Old Jun 7, 2016 | 11:42 AM
Jeff Blake's Avatar
Yeah, you're right, it is a hack. By hack I meant any sort of stop-gap measure. If there's a bum part, it should be replaced for longevity. I hate repairing things twice, or worrying about taking off the terminals and finding I can't tighten them back on later.
I also like the idea of mil-spec so I can angle the cables better. The battery dimensions have to be pretty precise (not only dimensions, but also -/+ posts location) for the factory terminals. I bought an optima and had to return it because of the location of the posts. Then I exchanged it for a regular battery, but 7.5" is too wide (my fault, should have measured... it fits, but the mount won't fit over it).
Attached drawing of proper battery dimensions
I'm going to go for it. Will report back
Old Jun 7, 2016 | 05:59 PM
gulfstream69xr7's Avatar
Originally Posted by number9
If current terminals in otherwise good condition may be best to use shims.
Exactly what I did. I had a flashing alternator light that I chased around for weeks, and could not figure out what it was. One of the forum members suggested checking my ground connections. I never could get the terminals to quite tighten all the way down. Shimmed the posts and tightened it up. No alternator light, no problems.
I don't see battery shims as a hack.
Old Jun 7, 2016 | 07:38 PM
number9's Avatar
Anothe more expensive option for cable is marine grade with tinned conductor.
Old Jun 11, 2016 | 01:35 PM
Jeff Blake's Avatar
I bit the bullet on the hydraulic crimper. Makes a world of difference. Even though I'm only going to be using them a few times... very much worth the $50. Welding cable is also amazing. Waiting on the larger lugs (ancor marine tinned copper) to do the install.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
the 4 gauge cable is for my fuse panel install.
Old Jun 13, 2016 | 12:19 AM
Jeff Blake's Avatar
job done. ended up making a new earth cable out of 2/0 gauge welding cable. Man, the bolt for the cable on the starter/block was really on there. Took 4+ hours of PB plaster, heat gun, vice grips, dremel, and sockets to get it off. Happy with the result. Now on to finishing my fuse panel and coolant hose changeover.
some final tips:
  • use a wire brush to scrape off any green residue on the cables after stripping. I had quite a bit on both positive cables
  • remember to check the position of the lug before crimping. You don't want to have to twist the cables to get it onto the terminal
  • hydraulic 10 ton crimper and welding cable is great stuff
  • 1/0 lugs for both positive cables
Old Jun 14, 2016 | 01:26 PM
JUKE179r's Avatar
Good job Jeff. That looks clean....
Old Jun 14, 2016 | 02:57 PM
NickAdams's Avatar
It does look clean. When you replace the battery, go with a group 31 for some extra lead plates and amperage. Mine fits like it was made for it!
Old Jun 15, 2016 | 07:34 AM
Best4x4's Avatar
I've got a Group 65 in mine!
russburcham
Jan 16, 2015 04:53 PM
Jossue Grijalva
Jun 3, 2013 07:01 AM
mherson
Oct 28, 2010 08:15 PM
PuroKaibil
Jan 16, 2009 07:59 PM
mowthat
Feb 7, 2007 03:48 PM
