Replacing Coils on SAI engine - any tips?
i certainly wouldn't try to do all of it in a single day on a brooklyn street in winter unless you know exactly what you're doing. i'm in staten island and have the luxury of a driveway, but even so i would set aside an entire weekend at minimum -- including periodic breaks to thaw out and trips to the auto parts store for bits you didn't realise you would need -- and i've had the intake off several times.
i've taken my intakes off seven or eight times. i don't know that i could do it in an hour until about the fourth time. the first few i seemed to remove bits that could be left alone. still, it isn't really a huge job. two hours at the absolute maximum.
getting the coil pack bracket off, swapping the coils, and re-mounting the bracket i would allow at least an hour. i climb up into the engine bay to do this. make sure you have good lighting and a telescoping magnet to grab the bolts when (not if) you drop them.
the valve cover baffle -- 10 minutes if it's an early style and it comes out easily in one piece. i just did my '03 and had to drill the thing out, which means removing the cover entirely. (i was doing head gaskets so they were coming off anyway.) on my '99 the baffle broke into several pieces and would have fallen into the rocker cavity if the cover had still been on the engine. so you're potentially looking at an hour or so there too, plus needing a new valve cover gasket and a deep 12-point socket for those stupid bolts.
injectors, yes, an hour. i got refurbs off ebay and they seem great. $65 for the set and i didn't have to return the cores.
reassembly from the injectors upwards i would allow two hours. you're going to get cold and you'll start to drop stuff. (i just spent two hours under my truck bolting the oil pan back on and reinstalling the thermostat. i didn't even get to put the drag link back because my hands stopped working properly.)
the biggest thing i can recommend is that you have everything you need in hand before you start. that's tools, rags, gloves, cleaners, parts -- everything. any time you have to stop to get something that you didn't realise you were going to need you're going to add an hour to your working time unless you live next door to autozone.
oh, and don't use bosch plugs. ngk iridiums is the way to go.
