Replacing Front Drive Shaft, What's next
Old Dec 23, 2012 | 11:27 PM
robdis96's Avatar
Default Replacing Front Drive Shaft, What's next
I am replacing the front drive shaft on my 00 DII and was looking around under the truck to see what else is on its way out. I'm going to do the fluids for the XMSN, TC, and Diffs because they need it. I typically do all my own work and am fairly mechanically inclined but I am not a suspension/drive train guru by any means. Should I be looking at replacing bushing, tie rod ends, etc.
While inspecting the front end when I pulled the DS I noticed that the rubber bushings at the steering knuckles looked like they were pretty much gone. Is that something fairly simple to fix/repair. Would rather not have to replace the knuckles if possible. Basically what should I expect next under the truck...
Thx
Rob
Old Dec 24, 2012 | 07:08 AM
Read my sticky at the top of this section and do it all.
Old Dec 24, 2012 | 02:57 PM
robdis96's Avatar
Got it printed, easy enough....
Thanks
Old Dec 24, 2012 | 04:26 PM
lr2001silver's Avatar
Banned
And yes to answer your question! You can do it rob!!!
DiscoJon
Jul 14, 2019 01:51 PM
robgusto
Sep 3, 2013 11:00 PM
jamieb
May 3, 2012 08:56 AM
TripleThreat
Apr 12, 2011 08:58 AM
Snafu / Disco Fries
Feb 27, 2011 05:53 PM
