Replacing Fuel Injector Seals-need advice
Old 06-03-2015, 08:08 AM
Andy2Rover's Avatar
Default Replacing Fuel Injector Seals-need advice
Hey Guys,
I will be replacing the injector seals on my 2000 D2 with 105k miles due to persistent check engine light indicating a vacuum leak. I've done a smoke test and didnt see anything significant, have replaced vacuum hoses and other assorted things that could leak, and havent been able to get the CEL to go away. After much forum searching, I am left to believe it is the injector seals.
There doesnt appear to be any "How-To's" on this DIY (which I may do), but it sounds rather easy. I have the RAVE to reference, but I wanted to check with you guys as well.
Here are my questions:
1-List of parts needed for the job (other than the injector seals)
2-Any other things I should replace while the intake is off? I'm thinking plug wires, coils, valve cover gaskets.....
3-Use RTV on the new intake gasket?
Thanks Guys!
Andy
Old 06-03-2015, 08:19 AM
drowssap's Avatar
1. you can get a rebuild kit on ebay
2. all good ideas to replace
3. your only removing the upper intake no rtv
have you tried an old fasion can of carb cleaner to find your leak?
Andy2Rover (06-03-2015)
Old 06-03-2015, 08:24 AM
dusty1's Avatar
Coil can be a costly pm replacement ...I'd prolly wait for that problem to arrive
Might check out valley pan
I also like to lightly lube the injector seals before I push them in... Used Dielectric last time , it was handy
Old 06-03-2015, 11:01 AM
Andy2Rover's Avatar
Have not tried the carb cleaner. I have no symptoms however (poor idle, etc.) so will I notice anything if I try spraying carb cleaner?
Old 06-03-2015, 11:22 AM
drowssap's Avatar
if your erratic idle is caused by a vacuum leak, when the carb cleaner hits it the idle should jump up
Old 06-03-2015, 01:14 PM
acamato's Avatar
you can use propane gas as an alternative to carb cleaner. I have used a propane soldering torch (not lit )
Old 06-03-2015, 02:25 PM
Andy2Rover's Avatar
Guys.....I DON'T have an erratic idle. The truck runs/idle's fine, I'm just trying to get the CEL off so I can pass inspection.
Drowssap.....are all EBAY injector seal kits created equal, or is one you like better than the others?
Thanks!!
Old 06-04-2015, 06:32 AM
drowssap's Avatar
run a search these should be a good writeup someone did a couple of month ago
Old 06-04-2015, 06:55 AM
acamato's Avatar
Thanks!!
A vac leak does not have to cause an erratic idle. You can use carb cleaner/propane to locate the vac leak. The idle will increase when the carb cleaner/propane makes it in to the intake then to the cylinders.
My DII ran great except would threw a code when I accelerated fast/high rpm (causing high vac). My leak turned out to be the intake hose on the TB was not seated right/tight enough.
What code are you getting?
Old 06-04-2015, 07:21 AM
Andy2Rover's Avatar
OK, good to know. I will give it a try. Thanks!
Quick Reply: Replacing Fuel Injector Seals-need advice
