Replacing Fuel Injector Seals-need advice
Old 06-11-2015 | 08:06 AM
Andy2Rover's Avatar
Originally Posted by MPDano
Painted the Upper Intake and Valve Covers. Pressure washed the Lower Intake. Almost ready for re-assembly. Going to replace the Valve Cover Bolts with some normal hex heads as those 12 points I no likey.
I hope you don't mind OP if I put my pics here. I can always start my own thread
No problem MPDano! You now have a Land Rover Testarossa!
  #52
Old 06-11-2015 | 10:22 AM
acamato's Avatar
Check to make sure the hex heads bolts will fit the recess in the valve covers. You may want to use a socket head cap screw. The head is a smaller diameter and will fit the recess in the cover.
  #53
Old 06-11-2015 | 10:36 AM
MPDano's Avatar
Good point. I brought one with me today to make sure the head will be the same or smaller.
  #54
Old 06-11-2015 | 10:37 AM
MPDano's Avatar
Originally Posted by andy2rover
no problem mpdano! You now have a land rover testarossa!
l r t
  #55
Old 06-11-2015 | 07:26 PM
MPDano's Avatar
Bummer, was so close as these Dormans fit nice in the cover, but are too short. Dorman doesn't make them any longer, just shorter.
Attached Thumbnails Replacing Fuel Injector Seals-need advice-20150611_155844.jpg   Replacing Fuel Injector Seals-need advice-20150611_155858.jpg   Replacing Fuel Injector Seals-need advice-20150611_155911.jpg
  #56
Old 06-14-2015 | 12:31 AM
MPDano's Avatar
Been working on the LR pretty much all day. Installed new valley and intake gaskets and valve cover gaskets. Installed new o-rings but not before giving them a good cleaning.
Should get the rest done tomorrow. Wow, what a job.
Attached Thumbnails Replacing Fuel Injector Seals-need advice-20150613_110427.jpg   Replacing Fuel Injector Seals-need advice-20150613_110442.jpg   Replacing Fuel Injector Seals-need advice-20150613_110449.jpg   Replacing Fuel Injector Seals-need advice-20150613_112122.jpg   Replacing Fuel Injector Seals-need advice-20150613_120438.jpg
Replacing Fuel Injector Seals-need advice-20150613_122412.jpg   Replacing Fuel Injector Seals-need advice-20150613_122420.jpg   Replacing Fuel Injector Seals-need advice-20150613_122432.jpg   Replacing Fuel Injector Seals-need advice-20150613_122626.jpg   Replacing Fuel Injector Seals-need advice-20150613_122713.jpg
Replacing Fuel Injector Seals-need advice-20150613_123148.jpg   Replacing Fuel Injector Seals-need advice-20150613_124137.jpg   Replacing Fuel Injector Seals-need advice-20150613_124248.jpg   Replacing Fuel Injector Seals-need advice-20150613_125054.jpg   Replacing Fuel Injector Seals-need advice-20150613_125103.jpg
Replacing Fuel Injector Seals-need advice-20150613_180001.jpg   Replacing Fuel Injector Seals-need advice-20150613_180009.jpg   Replacing Fuel Injector Seals-need advice-20150613_180018.jpg   Replacing Fuel Injector Seals-need advice-20150613_201803.jpg
Andy2Rover (06-14-2015)
  #57
Old 06-15-2015 | 12:36 AM
MPDano's Avatar
Intake Assembly completed. Changed out the oil and topped off the coolant with Dex.
She drove great driving for about a mile around the neighborhood, got home and can smell coolant. Got a coolant leak somewhere but it was dark, so will find the source and hopefully it is an easy fix.
The new plugs gave it a smoother ride and the new belt made it quieter.
Attached Thumbnails Replacing Fuel Injector Seals-need advice-20150614_192107.jpg   Replacing Fuel Injector Seals-need advice-20150614_192116.jpg   Replacing Fuel Injector Seals-need advice-20150614_192125.jpg   Replacing Fuel Injector Seals-need advice-20150614_192136.jpg
  #58
Old 06-15-2015 | 08:27 AM
Andy2Rover's Avatar
Good work dude! Thanks for the write up and pics!
Where did you get that injector cleaner?
  #59
Old 06-15-2015 | 08:47 AM
MPDano's Avatar
I made it. Found a great video on how to do it on youtube.
  #60
Old 06-15-2015 | 10:27 AM
MPDano's Avatar
Ended up buying the single 12 pt socket at the local mom n pop auto store for about $4. Worked like a charm. Also, don't forget the shorter bolts are on the inside.
