Replacing Fuel Injector Seals-need advice
Hey Guys,
I will be replacing the injector seals on my 2000 D2 with 105k miles due to persistent check engine light indicating a vacuum leak. I've done a smoke test and didnt see anything significant, have replaced vacuum hoses and other assorted things that could leak, and havent been able to get the CEL to go away. After much forum searching, I am left to believe it is the injector seals.
There doesnt appear to be any "How-To's" on this DIY (which I may do), but it sounds rather easy. I have the RAVE to reference, but I wanted to check with you guys as well.
Here are my questions:
1-List of parts needed for the job (other than the injector seals)
2-Any other things I should replace while the intake is off? I'm thinking plug wires, coils, valve cover gaskets.....
3-Use RTV on the new intake gasket?
Thanks Guys!
Andy
Thanks Guys!
Andy
Andy2Rover (06-03-2015)
Have not tried the carb cleaner. I have no symptoms however (poor idle, etc.) so will I notice anything if I try spraying carb cleaner?
My DII ran great except would threw a code when I accelerated fast/high rpm (causing high vac). My leak turned out to be the intake hose on the TB was not seated right/tight enough.
What code are you getting?
A vac leak does not have to cause an erratic idle. You can use carb cleaner/propane to locate the vac leak. The idle will increase when the carb cleaner/propane makes it in to the intake then to the cylinders.
