Replacing leaking head gaskets - what does my mechanic need to cover?
Old Jun 2, 2024 | 08:44 AM
mollusc's Avatar
Because you can't get to the centering ball to grease that unless you remove the shaft.
Old Jun 2, 2024 | 10:05 AM
H20nSnow's Avatar
Is that a particular issue on these, or is that just the philosophy of thoroughness? I've always pulled a used shaft the first time I service a truck and lube that joint thoroughly and treat it as a lifetime lube. But then, I've never subjected any of my trucks to particularly harsh conditions either.
Old Jun 2, 2024 | 06:07 PM
Extinct's Avatar
Probably more just thoroughness. Only takes about 15 mins to remove and 15 mins to put back. Besides lubrication gives you a good change to feel the wear in the joints. If it lets loose while driving you will have a very bad day.
BFox15
Sep 7, 2011 08:22 PM
RROJ
Mar 26, 2011 02:37 PM
Disco Ed
Feb 2, 2011 04:04 PM
Alex M.
Sep 30, 2009 12:34 PM
herblatham
Jun 25, 2008 09:50 AM
