Replacing valve cover gaskets, wires and plugs
Old Sep 29, 2009 | 02:25 PM
Alex M.'s Avatar
Default Replacing valve cover gaskets, wires and plugs
As the title says I'm going to be replacing these parts this weekend. I just have a couple of questions. First, should I use any type of silicone or gasket sealer for the valve cover gaskets? Second, I've developed a really annoying valve tick (or what sounds like a valve tick) and would like to know if there is any way I could check this since the covers will be off? Any input would be much appreciated. Also, I'm a new member and would like to say WOW!, this is a great forum!!! I look foward to learning from you all,
Thanks
BTW: It's a 99' Discovery 2, 106,000 mi.
Old Sep 29, 2009 | 03:21 PM
Send me your number and I'll try and answer your questions.
Old Sep 29, 2009 | 09:18 PM
Alex M.'s Avatar
Thank you for the quick response Mike. I'll send you a contact # when I get a chance, In the mean time if there is anyone else that would like to chime in please feel free! Thanks in advance,
Alex
Old Sep 30, 2009 | 08:14 AM
Eurotrash's Avatar
Thanks
could be an exhaust gasket.
Old Sep 30, 2009 | 08:16 AM
Exhaust leaks will/can tick, need to crawl under and check for exhaust stains caused from leaks, from the manifold to the cats.
Old Sep 30, 2009 | 10:28 AM
Alex M.'s Avatar
Ahhh, that's one thing that did not cross my mind. Thanks guys, I'll check into that as soon as I get a break here from work.
Old Sep 30, 2009 | 11:52 AM
humroot's Avatar
Thanks
To answer your first question, you do not need any sealer or silicone for the valve covers, you just need the new rubber gaskets.
Oh, and Welcome!
Old Sep 30, 2009 | 12:34 PM
jycsalas's Avatar
I didnt put anything on mine except for blue loctite on the valve cover bolts...
BFox15
Sep 7, 2011 08:22 PM
RROJ
Mar 26, 2011 02:37 PM
herblatham
Jun 25, 2008 09:50 AM
kumbhani123
Jun 12, 2007 04:22 PM
