Replacing my tcase this weekend
Old Aug 22, 2014 | 03:00 PM
ls1morethanyou's Avatar
Default Replacing my tcase this weekend
I am replacing my tcase- any advise would be appreciated.
from the threads i have read, i need to remove the front and rear shafts, then remove the rear drum assembly, remove connections to tcase, then drop and reassemble.
simple enough right?
Old Aug 22, 2014 | 03:09 PM
dusty1's Avatar
simple enough right? .............famous last words
Old Aug 22, 2014 | 03:59 PM
OffroadFrance's Avatar
Hmmm, simples https://www.google.fr/search?q=meerk...w=1280&bih=706 may I politely suggest you Google the subject, plan it and also have some muscular help and a good trolley jack and bolt on steel plate to drop it down. Unless you are of Herculean strength it requires some serious assistance as it weighs 55kgs+ and not easy to handle lying down underneath.
Replacing an LT230 Transfer box - Land Rover Technical Archive - LR4x4 - The Land Rover Forum .................. this will give you some insight on the subject, take care and good luck as we don't want to be reading your obit in the press.
Old Aug 22, 2014 | 04:16 PM
dusty1's Avatar
Juan......we call him hi lift because he rotates his tires, barefoot, without a jack. he'll probably have it out in 30 minutes using only a skateboard and an old tooth brush.
Old Aug 22, 2014 | 04:25 PM
It's the old toothbrush that makes all the difference, it's gotta be old ...........
Old Aug 23, 2014 | 08:17 AM
yeah, ive seen that thread- good pictures too but its on a D90- hopefully its about the same for the D2.
Work kinda got in the way, i eed to go fix a few things before i start so i wont be as gun-ho to drop it as i was yesterday but still excited to do it.
Ill be rocking flip flops till it gets cold, then its flip flops and socks
Old Aug 23, 2014 | 09:57 AM
Jared9220's Avatar
Good ol' Juan. Dusty's got the number to a good Doc to stitch you up if you crunch a toe or two.
When you get around to doing this can you take a bunch of pictures for the rest of us please?
I've been thinking of buying a used T-Case and rebuilding it and then just swapping the old one out so I have no down time on the truck. The only thing holding me back is I have no lift and will have to do the swap laying on my back. I'm just not sure I have that in me. If you don't mind I'll watch you struggle before I give it a go.
Old Aug 23, 2014 | 03:27 PM
Ooohhhh - whoosh.
x1
Coward
Old Aug 23, 2014 | 03:29 PM
Good luck - hope all goes well AND don't take any chances, broken bones are a serious setback
Old Aug 24, 2014 | 09:55 PM
Well, work called me in on saturday and i had to find the girl a new car as hers was totaled out and we got the insurance check in.
i drove through two tanks of gas to get her a vehicle we both agreed on, but it was worth it.
picked up an 05 jeep grand cherokee for 5k. not a bad day at all.\\\NOT
tcase duty might come on after brakes get done. :/
kevinb91
14
May 25, 2012 09:42 AM
EstorilM
Oct 11, 2011 08:13 PM
anything old
Sep 14, 2010 09:47 PM
brooksa
May 24, 2008 10:40 AM
fridgefreezer
Mar 3, 2007 10:42 AM
