Replacing a water pump and oil Pan Gasket
Old Jan 18, 2010 | 06:48 PM
adwarren78's Avatar
Default Replacing a water pump and oil Pan Gasket
Anyone done either of these, how hard, any tips or tricks, any suggestions on parts
Old Jan 18, 2010 | 07:00 PM
hilltoppersx's Avatar
do a search, both of these are covered elsewhere in the forum.
Old Jan 18, 2010 | 07:05 PM
okdiscoguy's Avatar
relatively easy. On the oil pan, I would go ahead and drop the crossmember, track rod and stabilizer so you have plenty of room. Don't have to have a gasket. You can just use sealant.
Fan clutch is the hardest thing about the water pump.
Do a search, there are some write ups..
Old Jan 18, 2010 | 07:13 PM
lipadj46's Avatar
On the crossmember be careful the bolts snap off pretty easily. I don't think it is structural more for protection so if all the bolts don't make it don't sweat it, drill them out and use a nut and bolt. The viscous fan is the hardest thing, it is 36 mm northern tool sells a 36mm wrench and the Ford wrench from autozone works too. Some have had luck with thin adjustable wrenches also. You need to hold it from spinning somehow, search around for different options. Also use a thread sealer on the water pump bolts (not a thread locker, permatex makes a thread sealer).
Old Jan 19, 2010 | 05:40 AM
oljohnboy's Avatar
Leave the belt on the fan, work around it, it will keep it from turning.
outdoor7or24
Dec 22, 2014 09:31 PM
mike111
Jun 2, 2014 08:58 AM
me 2
Jun 13, 2012 06:42 AM
ljdiscovery
Feb 27, 2010 06:57 PM
