reset adaptive values of CPS
I just replaced the CPS on '02 DII and the truck still won't start. I double checked all connections to make sure they were correct. Rave says that adaptive values need to be reset with test book anytime the CPS is removed. Is there a way I can do this without Testbook? or do I have a different problem all together?Thanks
Lord, I was driving when the truck suddenly stalled. After starting right up again, the truck died once more after about ten minutes of driving. This time it did not start up. I thought it might be the Alternator, I put a new alt in and had the same symptoms. Reading about CPS in Rave made me think that it had gone bad.
Mike, I did not test new sensor with OHM
carnut
40
02-19-2011 06:50 PM
Chrisinhouston
04-09-2010 04:58 PM
