reset adaptive values of CPS
Old Feb 5, 2011 | 04:26 PM
wiscodread's Avatar
Default reset adaptive values of CPS
I just replaced the CPS on '02 DII and the truck still won't start. I double checked all connections to make sure they were correct. Rave says that adaptive values need to be reset with test book anytime the CPS is removed. Is there a way I can do this without Testbook? or do I have a different problem all together?Thanks
Old Feb 5, 2011 | 04:32 PM
I see lots of people weekly that install new crank sensors and have never heard them say they had to, truck just starts right up.
Have you done the sensor test with an OHM meter to verify your new sensor is sending a good signal?
Old Feb 5, 2011 | 04:37 PM
lordmorpheus's Avatar
Most importantly, what was the vehicle doing that caused you to think it needed a new CPS? If a running or no-start problem was misdiagnosed, replacing a good CPS with another one won't solve anything.
Old Feb 5, 2011 | 04:56 PM
wiscodread's Avatar
Lord, I was driving when the truck suddenly stalled. After starting right up again, the truck died once more after about ten minutes of driving. This time it did not start up. I thought it might be the Alternator, I put a new alt in and had the same symptoms. Reading about CPS in Rave made me think that it had gone bad.
Mike, I did not test new sensor with OHM
Old Feb 5, 2011 | 04:58 PM
You have been looking in the wrong direction.
Send me your number and I'll call you right back.
Old Feb 5, 2011 | 05:05 PM
wiscodread's Avatar
ok thanks
Old Dec 17, 2023 | 08:46 AM
Mo 3's Avatar
having somewhat of the same issue if you could reach out to me as well?
Old Dec 17, 2023 | 11:06 AM
mollusc's Avatar
12 years since the last post here.
Disco Mike is no more. He's not going to call.
Childeric
Apr 9, 2014 11:43 AM
Bamberson
Sep 16, 2012 07:36 PM
carnut
40
Feb 19, 2011 06:50 PM
rhino_e28
Sep 28, 2010 12:38 AM
Chrisinhouston
Apr 9, 2010 04:58 PM
