Resleeve!
Old Feb 24, 2012 | 07:21 PM
jbarrios60's Avatar
Default Resleeve!
I'm getting my 2003 engine back from la sleeve next week and will begin putting it all back together. Wish me luck. Full resleeve
Old Feb 24, 2012 | 08:05 PM
please post pix! We know what they look like on the outside...
Old Feb 25, 2012 | 09:09 AM
Rearden Steel's Avatar
Did you send the block away or have it done locally?
Did you use top hat sleeves?
Are you going to do any other mods?
(Change out the crank to a Buick 350)
Old Feb 26, 2012 | 08:28 PM
jbarrios60's Avatar
Default local, I'm in LA,CA
I dropped off my clean block @ LA Sleeve.
Flanged/ top hat liners.
Other Mod. will b Kent Cams, H-180 Cam shaft
New rings, full bearings,front cover
Will try and post pix of it when I get it back, bare.
Luck?
Old Feb 27, 2012 | 08:54 AM
94svt50's Avatar
What motivated you to do the top hats?
Old Feb 27, 2012 | 06:38 PM
jbarrios60's Avatar
Default reading, lots of reading
I did lots of fun reading and looking at what others are doing out there to cure this. LA Sleeve is not far from me and after talking to them they say they've done lots of these. Other option was a new block or a remanu. at over 5K
Block seems to be the main issue. I'm in the castings business and can kind of understand the issues, alum block, porosity, thin walls, thermal expansion, steel liners, thin/small seal at heads, then add pressure,,,,,
First attempt at this, put in new front cover and new stock cam shaft. original cam had some odd wear on one lobe. reassembled turn over, warm up, Knock,Knock. Same as before. This time pulled it and complete tear down. only isuue found was that one liner had what I would best describe as a wave down the inside of it. were the others felt smooth from top to bottom. Still a bit apprehensive but hopeful.
Funny this block has been around since the early 60's (Buick) and has been bored out. probably beyond it's max. (wall thickness) thin wall alum and pressure don't do well. OK Motors is going another step and adding a ceramic dip coating then baking it on to seal the blocks porosity. I had a customer going that route to cure their problems with some small cast parts that needed to function under pressure.
Old Feb 27, 2012 | 07:23 PM
94svt50's Avatar
sounds like a good move, let us know how it works out.
Old Feb 27, 2012 | 08:01 PM
Stroke it while you have it apart.......
Old Feb 27, 2012 | 10:25 PM
HLC Fab's Avatar
Ditch the stretch bolts when you put it together and get a set of ARP head studs.
Old Feb 28, 2012 | 09:43 AM
0304Disco's Avatar
What is the cost to resleeve? I have a spare block that I would consider the investment for my 03'?
