Restoration & Weak Brakes Advice
I've been restoring my 03 Disco and need some advice or direction on the brakes. All braking components have been replaced - brake lines, brake pads, rotors, a couple calipers (not all), the ABS master cylinder and ABS module (rebuilt and reprogrammed), couple fluid flushes, etc. But the brakes are still extremely weak. I owned one of these new and know it's a far cry from what it should be. You can push the brake pedal as far as it'll go and the car comes to a slow stop. There's absolutely no activation of the anti-lock braking...no way it comes close to being able to lock up the wheels. The only thing left to replace is the brake booster, which you can't find a new or aftermarket part there. I did just order one on eBay that's used but said to be in good working condition...along with the brake booster vacuum line and intake host fitting, just for good measure.
Does anyone have anything other input on this? I've got some other things to throw around regarding my restoration process but figure this'll be a good conversation starter.
jastutte (11-16-2023)
binvanna (11-17-2023)
