Restoration & Weak Brakes Advice
Old Nov 16, 2023 | 01:34 PM
Tyler Rognlin's Avatar
4th Gear
Exclamation Restoration & Weak Brakes Advice
I've been restoring my 03 Disco and need some advice or direction on the brakes. All braking components have been replaced - brake lines, brake pads, rotors, a couple calipers (not all), the ABS master cylinder and ABS module (rebuilt and reprogrammed), couple fluid flushes, etc. But the brakes are still extremely weak. I owned one of these new and know it's a far cry from what it should be. You can push the brake pedal as far as it'll go and the car comes to a slow stop. There's absolutely no activation of the anti-lock braking...no way it comes close to being able to lock up the wheels. The only thing left to replace is the brake booster, which you can't find a new or aftermarket part there. I did just order one on eBay that's used but said to be in good working condition...along with the brake booster vacuum line and intake host fitting, just for good measure.
Does anyone have anything other input on this? I've got some other things to throw around regarding my restoration process but figure this'll be a good conversation starter.
Old Nov 16, 2023 | 04:54 PM
Tony Luna's Avatar
You may need to do a power bleed.
Old Nov 16, 2023 | 05:01 PM
jastutte's Avatar
there are probably air bubbles caught in the ABS module. do you have a scanner that can bleed the module?
Old Nov 16, 2023 | 06:26 PM
Extinct's Avatar
Firm pedal or is it soft? Vacuum test your booster and see if it holds vacuum overnight.
Old Nov 17, 2023 | 01:38 PM
miron's Avatar
Do the ABS bleed by shorting the relay. You will need to bleed the module, then lines and repeat b/c it will be pushing air towards the calipers.
Also follow the correct bleed order described in rave
Old Nov 17, 2023 | 03:35 PM
binvanna's Avatar
Have you replaced the vacuum booster? Had to change mine twice. When it's bad, the pedal is firm, but brakes are weak.
Old Nov 17, 2023 | 03:49 PM
zski128's Avatar
Also check the RAVE manual for the proper order to bleed from the calipers.
Old Nov 18, 2023 | 11:08 AM
longtallsally's Avatar
Yeah, I’m on the bleeding procedure. Did you use something to cycle the ABS pump? If you’ve replaced that much, it’s almost certainly a few bubbles in there.
Brandon318
Sep 18, 2021 04:08 PM
Merlin1971
Jun 13, 2021 11:19 PM
escott16
Nov 25, 2017 10:22 AM
Rogercarsonsmith
Jun 25, 2017 08:35 AM
jayaimzzz
Dec 23, 2013 07:14 AM
