new brakes on 03 disco but still mushy
Old Jun 24, 2017 | 08:04 PM
Rogercarsonsmith's Avatar
6th Gear
Default new brakes on 03 disco but still mushy
My 03 disco has extremely mushy brakes and I cant figure it out! Its got new Brakes and rotors and Ive checked the brake fluid. All appear to be fine... The only other thing I can think of is a brake fluid flush. I'm stumped and need help. Anyone have valuable input?
Old Jun 24, 2017 | 08:08 PM
Luckyjayb's Avatar
Check the vacuum line from the booster to the intake for a possible leak and if not try bleeding them according to the rave manual
Old Jun 24, 2017 | 08:18 PM
The Deputy's Avatar
Do they seem to get better after pumping them up a few times?
Master cylinder is a common failure part on these things.
Brian.
Old Jun 25, 2017 | 07:47 AM
CollieRover's Avatar
It could also be the brake hoses are worn out. I switched to the stainless steel kit from AB, and my brakes seemed stiffer. Full disclosure, I did a full brake job at the same time though.
Old Jun 25, 2017 | 08:35 AM
Best4x4's Avatar
I've also seen people chase vacuum leaks for mushy brakes and they never actually find it. They replace the MC, and do countless bleeds with no change. I saw a D2 come into the LR shop for the same thing once and it took 3 guys looking it over to finally figure it out. The actual intake manifold was loose causing a decent vacuum leak. I've also seen the gasket leak (normally due to someone re-using it).
When I bought my Kalahari she had a mushy brake pedal. Turned out my intake manifold bolts were all loose. Tightened them down and my pedal is perfect. Just something to check. Also if you don't have SAI make sure the vacuum nipple that isn't used has a good vacuum cap over it that isn't leaking.
asmcmillin
Jul 2, 2023 04:25 PM
jamestfl
Jan 16, 2017 02:29 PM
jrm123180
Nov 16, 2011 10:33 AM
EL GALLO
Apr 21, 2010 10:10 PM
ryanrover
Dec 5, 2007 07:19 PM
