Rhythmic tick from bottom of front cover
Old Apr 16, 2020 | 04:08 PM
ttownthomas's Avatar
Originally Posted by No Doubt
if you hear the tick even with a cold motor and it increases with RPMs and never goes away, then clearly you have a real issue.
it’s there all the time. Definitely coming from inside the motor. Gonna check the oil pressure next.
Old Apr 16, 2020 | 06:19 PM
boston4's Avatar
You might also consider posting a video of the sound you're hearing.
Old Apr 16, 2020 | 06:28 PM
Posting a video next
Old Apr 16, 2020 | 06:41 PM
View this post on Instagram
Here is the video. Im zeroing on the loudest spot from the stethoscope and you can really hear the tick before and after the fan noise.
Old Apr 16, 2020 | 07:02 PM
Red5's Avatar
IDK, those pressures look pretty good. I would remove the belt and run it for just a bit without any accessories just to rule those out before I pulled the engine cover. If it remains, then on to the pump.
Old Apr 17, 2020 | 06:28 PM
Extinct's Avatar
Oil pressure is not bad, I would not expect a cracked pump to do that. Good idea on running it with the belt off. Does it do it stone cold? Does it do it at highway speed? You might want to pull all the plugs, put a wrench on the crank pulley and see if you can feel anything like a hitch at one spot in the rotation.
Old Apr 17, 2020 | 07:33 PM
No Doubt's Avatar
Right, but one more test when cold before replacing the oil pump: duct tape your shop vac to your exhaust with motor OFF but run the shop vac and then listen for a leaky "exhaust" up front.
Old Apr 18, 2020 | 11:44 AM
Did the shop vac test. Got under the car with a stethoscope. Could not find any exhaust leaks. Took the serpentine belt off and the noise is still there. Its hard to hear from inside the car so you cant rally hear it when driving and the noise is 99% for sure coming from the bottom of the front cover. You can barely hear it from the top with the hood open because the fan and the rest of the normal noises are drowning it out. I feel strongly that either it is the oil pump or some other bottom end ticking transmitting through the crank.
Old Apr 18, 2020 | 07:47 PM
Ugh....Fighting with the fan, can't get it off. I don't have a big enough pipe wrench do I need to make a tool?
Old Apr 18, 2020 | 07:53 PM
Extinct's Avatar
I know O'reilly rents their fan removal tool, your local auto parts store might as well.
