Rhythmic tick from bottom of front cover
Old Apr 18, 2020 | 08:12 PM
  #21
11chuck's Avatar
Originally Posted by ttownthomas
Ugh....Fighting with the fan, can't get it off. I don't have a big enough pipe wrench do I need to make a tool?
32mm spanner to get it off, if I remember right. You can give it a good whack to start it off, or use a 10mm wrench to hold one of the WP pulley bolts as you break it free. After that it just spins off.
Old Apr 18, 2020 | 08:59 PM
  #22
Sixpack577's Avatar
Standard 1' long adjustable wrench fits and loosens/tightens my fan.
I hit the wrench handle with a dead blow hammer once and it breaks loose.
The original fan came off as easily also.
I have a fan wrench set too, but the adjustable jaws are wider, and it's easier to grab the wrench than open the plastic case for the fan wrench.
Old Apr 26, 2020 | 09:56 AM
  #23
ttownthomas's Avatar
After fighting with the fan last weekend for 4 hours I bought a wrench set. Came off in 3 minutes. A few hours later I got the front cover off. Here is the oil pump gear and a video showing the play in the chain. I'm hopeful that this was the noise I was hearing. What else should I be looking at in here. I'm going to replace the pump gears and the chain.
View this post on Instagram
Old Apr 26, 2020 | 03:53 PM
  #24
No Doubt's Avatar
Yeah... I don't remember having that much play in my new timing chain when I did mine.
Old Apr 26, 2020 | 03:59 PM
  #25
boston4's Avatar
Which fan tool did you get? I tried to get mine off with this one yesterday but couldn’t get it.
Performance Tool - Ford Fan Clutch Wrench Set (W80585) Engine
Amazon Amazon
Old Apr 26, 2020 | 04:04 PM
  #26
Performance Tool - Ford Fan Clutch Wrench Set (W80585) Engine https://www.amazon.com/dp/B0002KO3AQ..._2yFPEbFESGQ3J
https://www.roverparts.com/engine/tools/61600/
and the accompanying flat spanner.
Old Apr 26, 2020 | 04:19 PM
  #27
Extinct's Avatar
That chain is not bad - but if it makes you feel better they are not expensive so little harm in replacing it. How was your oil pressure with that pump?
Old Apr 26, 2020 | 06:31 PM
  #28
cold 55 pounds at idle.
hot 15 at idle and 45 at 2000 rpm
Old Apr 26, 2020 | 08:48 PM
  #29
Extinct's Avatar
Interesting, given the broken oil pump gears.
Old Apr 26, 2020 | 09:28 PM
  #30
Timing cover gasket mating surface and gears all cleaned up. New chain installed. Need to borrow an inch pound torque wrench from a friend tomorrow so I can install the oil pump cover correctly.
