Riddle me this?? Car starts when I hit the hibeams
So I noticed today while driving my wife's disco that after driving for a while if I touched the brake pedal or if I flashed the high beams I got the three tones that I assume means the ecu is throwing a code. (I have gotten the code that says low voltage to what I assume is the ecu before). I stopped the car and shot it off for five minutes and when I got back in nothing happened when I turned the key so of ****s and giggles I pulled the high beam stalk back and low and behold the truck turned right over. I was able to repeat this two more times when the truck didnt turn over when the key was turned.
Any ideas?
Thanks
Eric
Any ideas?
Thanks
Eric
Your XYZ switch is mal-adjusted and you bumped the shift lever while turning on the headlights.
You recently ripped out the factory radio and put in an after market.
Some bonehead put in a car alarm.
Your key switch where you put the key into is going bad cause you have 170,000 or more miles on the truck and your key ring has about 15 to 20 keys on it. Too heavy.
amer_qureshi
06-08-2022 05:44 PM
