Rocker replacment
Old Jun 21, 2013 | 11:22 AM
groeder24's Avatar
Default Rocker replacment
I am rebuilding a motor and just got my heads from Will Tillery. I'm planning on replacing the wearable parts such as lifters, pushrods, rockers and rocker shafts. Is it necessary to replace the springs and other little parts on the rocker assembly or do they not wear?
Old Jun 21, 2013 | 11:38 AM
drowssap's Avatar
either put back what you have or buy a cam & lifter set
Old Jun 21, 2013 | 11:51 AM
groeder24's Avatar
Cam will be replaced. And like I said lifters and rods will be replaced as well but the rocker assembly is on backorder and is a bit pricey @ $400 per assembly considering I can rebuild both shafts (rockers and shafts) for $300 total. just wasn't sure on the springs and such.
Old Jun 21, 2013 | 11:58 AM
drowssap's Avatar
your talk about the spring and washers on the rocker shafts? why not if everything else is new no sense cheaping out now.
Old Jun 21, 2013 | 12:04 PM
Coyote's Avatar
If the assemblies are on B/O, I would buy the shafts and rockers and reuse the old springs and washers. Assembling them is easy, just make sure you check for the notch on the end of the shaft, and make sure the rockers are on the right way. I believe the push rod side of the rockers goes on the same side as the notch, but check the RAVE to be sure.
Old Jun 21, 2013 | 12:13 PM
groeder24's Avatar
Mainly because I am not finding them readily available and if the springs and washers aren't normal wear items, why spend the extra $50. I'm not cheaping out, I'm just not into spending money that doesn't need to be spent.
Old Jun 21, 2013 | 12:31 PM
drowssap's Avatar
they can be reused with no problem
neroverguy
Feb 24, 2010 08:35 AM
Rich 00 DISCO
Apr 24, 2009 11:18 AM
MLandry7
Dec 3, 2008 09:38 AM
Chillbilly
Jun 4, 2008 03:51 PM
cpl55
Apr 20, 2007 01:06 PM
