Question on dashboard lights
Old Jun 20, 2013 | 11:21 AM
Chrisinhouston's Avatar
Default Question on dashboard lights
Most of my driving seems to be in the daytime but I had to run out after dark the other night and noticed that the part of my dashboard where the odometer and gear indicator are is no longer lit up. Haven't removed it yet for a look, does anyone know if this is lit by a bulb that can be replaced or is is LED or something? I guess it isn't that big of a deal as the red lights work next to the gear shift so I can see what gear I am in and I don't typically look at the odometer that much.
Old Jun 20, 2013 | 05:15 PM
Did you turn down the dimmer switch on the left side of the steering wheel.
Old Jun 20, 2013 | 06:45 PM
jafir's Avatar
It's a small bulb that can be replaced, not too much work.
Old Jun 20, 2013 | 10:29 PM
bballjames's Avatar
I believe it's the same bulb as behind the clock.
Old Jun 21, 2013 | 01:40 PM
I had to laugh at first at DM's response but I've seen plenty of computer help desk reports of people whose computer won't power up and the switch in the back is turned off or they are unplugged!
However I checked it and it is in the on position, the other lights all work so it must be that bulb. I think I actually have another dash cluster in my spare parts box and will check it for the bulb required.
Tropical Disco
Jul 1, 2008 03:24 AM
Chrisinhouston
Mar 2, 2008 05:21 PM
dgm
Feb 18, 2008 09:03 PM
Discoverydiesel2003
Nov 13, 2007 07:09 AM
jonnymcd
Jul 25, 2007 03:11 AM
