Rocker Shaft Wear- Too Much?
Old Apr 27, 2010 | 02:24 PM
David Kadasia's Avatar
Default Rocker Shaft Wear- Too Much?
Rocker shaft is worn on the underside. Towards the ends of the shafts the wear is .002 and toward the center the wear is .004. The rockers have cut a groove on the underside only. Do these shafts/rockers require replacement? What will happen if they are used? Valve clatter? Poor oiling?
Suggestions or ideas? If I don't have to replace these, would be nice not too!
Thanks
Dave
1997 Disco Engine
Attached Thumbnails Rocker Shaft Wear- Too Much?-right-cylinder-head-016.jpg   Rocker Shaft Wear- Too Much?-right-cylinder-head-017.jpg   Rocker Shaft Wear- Too Much?-right-cylinder-head-018.jpg
blackcloud
Feb 6, 2011 01:21 PM
Aj6543
Nov 10, 2010 10:41 PM
began
Nov 23, 2008 08:59 AM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
