Roof rack lighting help
Old Feb 15, 2013 | 09:01 PM
bigcraigman's Avatar
Default Roof rack lighting help
So I have a question... Does the wire going to my headlights high or low beam necessary? Should be step 12 on the photo included. I would rather just use the switch but if is necessary then what's the best way to find the wire?
Old Feb 15, 2013 | 11:52 PM
Bkreutz's Avatar
The reason they do that is that in most (if not all) states it's illegal to operate auxiliary lights without the headlights being on. Kind of a CYA thing IMO. There are "work arounds" but I"m not going into detail on a public forum but I will say that that wire would need the same input that an operating headlight would provide.
Old Feb 16, 2013 | 06:35 AM
So what's the best way to find the high beam wire?
Old Feb 16, 2013 | 09:04 AM
Bkreutz's Avatar
Depending upon where you will be mounting the relay, go to the closest headlight, turn the high beams on, then probe the wires coming out of the back of the headlight with a test light or DVOM to find the wire that has power, then turn off the lights and make sure the power is not there with the high beams off. Now you've found your signal wire.
Old Feb 16, 2013 | 10:04 AM
Run a separate switch for the top lights, it will work alot better that way.
Old Feb 16, 2013 | 07:34 PM
So I can just run a hot wire from the battery, attach a ground and put a switch on the hot wire?
Old Feb 16, 2013 | 08:16 PM
According to the RAVE electrical diagram, in living color, the high beam wire is blue and orange and appears thru fuse 9 and fuse 22 under dash. Each side of truck is separate fuse.
Please - use a relay to switch your lights, and be sure everything you attach to battery power has a fuse nearby. The truck you save may be your own.
Old Feb 16, 2013 | 08:23 PM
The wiring I have came with a relay and a fuse in line. But it wants you to hook it up through the high beams. I just want to keep it simple and turn it on when I want to without wiring it through the high beams. I will probably run it tomorrow and see if it still functions without it.
Old Feb 17, 2013 | 03:44 PM
So I ran the wires and got everything cleaned up. Still have no idea how to hook it up through the lights. I ran the switch directly to the battery pos terminal and everything works. I would like to just leave it on the battery but will that continue to draw a d eventually kill my battery?
Old Feb 17, 2013 | 03:54 PM
souljad9's Avatar
You can use a fuse tap, like this:
Cooper Bussmann/ATM fuse tap (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
and tap the power for the switch off there. Then just one wire out to the relay.
