Roof Rattle - Disco II
First, remove the rear torx screw on one side and loosen the front one. This is more tricky then it sounds as there isn't a lot of room to work. For the rear, I tilted the roof I think and than I have a small socket type driver that allows the bits to be installed through it, so that was shallow enough to access the rear screws, but not the front. Otherwise you can just use a torx bit and a wrench if you have one small enough or pliers to turn it (I used needle nose vice grips). Loosen but don't remove yet. Shift the roof back until there's room to access the front torx screw, but give yourself some room to still be able to access the rear, and then loosen the front as well. Than if you remove the rear screw completely (also can be done outside the truck from the top), you should be able to push the track bracket out far enough to put your new roller on and slip it back into the rail. It's a pretty snug fit, but it goes. Put the rear screw back in and snug, tighten the front, move it forward, tighten the rear and then repeat for the other side.
Them enjoy not having to wonder if your roof is going to fall off as you drive!!
