Rotoflex - Necessity of Centering Bearing Replacement
Old Jun 23, 2020 | 03:25 PM
mln01's Avatar
Wow. Asked, and answered! Clearly it is subject to wear. Thanks for the pics
Old Jun 23, 2020 | 05:47 PM
boston4's Avatar
Yeah, I guess I'm just not sure how much of that wear was caused by the removal process. I think I'll plan on not replacing it initially and see how it goes. As @Dave03S said above - one thing at a time.
Old Jun 23, 2020 | 07:23 PM
merebel's Avatar
I was wondering about this from lucky 8 on the rear drive shaft update.
https://lucky8llc.com/collections/di...conversion-kit
Old Jun 24, 2020 | 01:33 PM
frostythor's Avatar
this is how I remove Spigot bush, it should work on the rotar flex bush
Old Jun 24, 2020 | 04:39 PM
boston4's Avatar
Might be better off with AB on this one - includes all of the hardware for only $20 more.
https://www.roverparts.com/driveline...e-shafts/9300/
Old Jun 24, 2020 | 04:44 PM
merebel's Avatar
Ohhhh
Old Jul 27, 2021 | 07:12 PM
DiscoID's Avatar
Default Centralizing bushing removal
Originally Posted by boston4
Here's the centering bearing/bushing:
Can I ask the method that you used to get yours out? I've got some wear on mine and been fighting with it using the pump grease in & hit a bolt/socket & extension the size of the center opening to use the hydraulic action of the grease to try to press the bushing out - see this YouTube clip, but replace a bolt the diameter of the pump tool (which is $$$$$ and not an option for me to buy):
As you see, this is similar to the method in the other video in the thread. My centering bushing is not budging using this method. I've even heated up the end of the driveshaft where it presses in, but can't get any movement. A lot of grease mess, a few destroyed sockets and extensions and a full tube of grease. Just headaches so far and a disabled '03 in the driveway to date.
Old Jul 28, 2021 | 11:15 AM
boston4's Avatar
Never actually swapped it. I was just quoting a different post from 2013.
https://landroverforums.com/forum/di...56/#post392832
Old Jul 28, 2021 | 12:41 PM
Discorama's Avatar
I couldn't see any difference (no wear) to the new one, so I left it in.
Old Jul 28, 2021 | 01:10 PM
DiscoID's Avatar
I'm going to go the same route and leave it in. I can't get it out anyway, so RWYB it is!
