Rotoflex question
Old 03-16-2011, 05:56 PM
coors's Avatar
I just went through the rave - I think you are you referring to the front shaft? I don't see a bearing in the rear shaft. I think, you're thinking of the centering ball in the front cardan joint.
Old 03-16-2011, 05:58 PM
coors's Avatar
But... A quick look at AB's site brings this. Is the bearing the little black/silver cylindrical component on the bottom left??
Old 03-16-2011, 06:30 PM
PalmettoDisco's Avatar
Yes, it's more a bushing than a bearing. A torch is ideal, however, not having one I used a Dremel to grind down the old one on opposite sides then squeezed the sides in with a vise then having a little clearance from the driveshaft I cut the thinned metal with a chisel and hammer. The last quarter inch I pried it out with a heavy screwdriver.
Old 03-16-2011, 08:56 PM
texmbr's Avatar
That's it...the centering bushing/bearing. I'm going to tackle it this weekend and have slide hammer, dremel, torch and assorted other tools gathered. Gonna see how it goes.
Old 05-18-2011, 10:05 PM
outback96's Avatar
So after inspecting the rotoflex I found that there was numerous cracks on its surface. I thought that this was the cause of my vibration at 70mph +, however after installing it today that's not the case. I still have the vibration at 70mph, but after closure inspection it seems to be more towards the front of the truck...so I'm now thinking more in the front drive line. I've recently greased the U joints and all took new grease until new pumped out. Any thoughts.
Old 05-19-2011, 07:29 AM
sloan74's Avatar
put the dremel on it. might be the best tool I own...lol
Kalel
05-15-2012 07:10 PM
BajaXJ92
12-13-2009 09:35 PM
mellyagaunce
09-30-2008 10:26 PM
sailorcolin
04-14-2008 09:20 PM
willstevens
01-02-2008 07:58 AM
Quick Reply: Rotoflex question
