Rotor Rust
Old Oct 2, 2021 | 02:35 PM
cvhyatt's Avatar
Default Rotor Rust
Any of you guys put any sort of coating on the wheel hub portion of the rotor to prevent rust?
Old Oct 2, 2021 | 02:50 PM
zski128's Avatar
Some manufacturers have an e-coating applied to the hub of the rotor, I try to stick with that. For the inside of the hub that touches the wheel bearing I put a thin coat of antisieze. I think paint would be your only
option as heat will bake off fluid film, etc. Maybe brake caliper paint?
Old Oct 2, 2021 | 03:13 PM
Best4x4's Avatar
My Brake Motive Rotor's are Zinc coated and still look basically new. I use a wire wheel on a drill to clean the backside of the rim where it mates to the rotor. Makes removal a breeze! Some P38/D2's I've worked on the hardest part of the darn job was getting the darn wheels off due to corrosion between the rim/rotor.
Old Oct 2, 2021 | 04:29 PM
Extinct's Avatar
I use spray chain wax. Coats it with a lubricating wax that is dry and will not attract dirt.
Aj6543
Mar 26, 2021 10:27 PM
redwhitekat
Jul 15, 2020 05:19 AM
Spencerfitch
Sep 2, 2010 08:51 PM
Aj6543
Sep 30, 2008 09:50 PM
apcollin
Aug 23, 2008 08:01 PM
