Rough Acceleration
Old Dec 10, 2008 | 06:14 PM
black bear's Avatar
5th Gear
Default Rough Acceleration
I have owned my 2000 Discovery II for 5 years, 123,000 miles. Several months back I swapped out the plugs and wires due to misfiring. All has been well, until this week. I changed my oil and filter Sunday evening. Today my wife noticed the truck riding rough during acceleration. The engine sounds fine in park even when I rev the rpm's. It feels like a misfire, but my experience and gut tell me it is something else. Could it be the transmission? I used synthetic oil this time, if that helps.
Old Dec 10, 2008 | 06:24 PM
Switzer's Avatar
Default RE: Rough Acceleration
Has the front driveshaft ever been replaced? This might seem like a chaos theory speculation, but the driveshaft may be on its way out. The original driveshaft does not have any grease fittings and are known to explode as they age.
Cheers,
Pete
Old Dec 10, 2008 | 08:12 PM
Sounds like you need another tune up, make sure that you only use Magnecor or LR plug wires.
Old Dec 11, 2008 | 08:51 AM
Is your check engine light on, what brand of plugs and wires did you install?
Better describe this roughness.
Yes, it could also be a front dive shaft, have you ever had the 2 greaseless u-joints replaced?
Old Dec 18, 2008 | 10:13 PM
black bear's Avatar
5th Gear
My check engine light is not on. I used the auto zone cheapo cables, but good plugs. It just feels different than the plugs and wires. I can't explain it but different.
I have never had the greaseless u-joints replaced. Are the u joints part of the drive shaft? Where can I find a picture of diagram of the u-joints?
Old Dec 18, 2008 | 10:21 PM
black bear's Avatar
5th Gear
Never mind. I found Tom Woods' site.
Old Dec 18, 2008 | 10:43 PM
sloppyjoe's Avatar
any chance the wifey put 87 octane gas in the rig?
Old Dec 18, 2008 | 10:53 PM
LRScott's Avatar
Chances are those cheapo spark plugs and wires are causing the issue. Make sure you use the Magnecores or LR Plug wires like Spike suggested.
Old Dec 18, 2008 | 11:09 PM
black bear's Avatar
5th Gear
Yeah, I am leaning on the plugs and wires, since the rough ride comes with some loss of power. Would loss of power be a symptom of driveshaft issues?
Old Dec 18, 2008 | 11:11 PM
sloppyjoe's Avatar
ORIGINAL: black bear
on any other vehicle i would say no, but its a LR. these things are a "special" kind of breed.
