Rough idle and high coolant temps
2004 Land Rover Discovery II 4.6 122k miles
Rough Idle: Ive posted a few weeks ago about the rough idle and had no luck. The LR idles rough and ive replaced spark plugs, wires, coil packs. Ive also replaced the thermostat, flushed radiator, new coolant, greased ujoints, oil changed. Today I cleaned the throttle body..not sure what else to do to get rid of the rough idle.
High Coolant: Today I had the OBD reader hooked up while I was driving and the coolant temps were ranging around 215 going down the road and stayed around 221 when idle. I thought for sure the new thermostat and coolant would help this problem. According to other forums those temps are too high..any advice what I should check out next?
I would say those temps are a worry. System defo bled properly. No air locks?
Jmcbghs2012 (03-27-2016)
Some ppl get better results with fewer tries than others, (doing this has worked for me every time)
