Rough/stumbling idle 2001 discovery 2
I have a rough/stumbling idle it started out to just do it here or there at red light now it’s almost always at idle. I have no check engine light. I have replaced spark plugs,coils,wires,fuel injectors upstream o2 sensors I cleaned idle air valve, oil separator. I really don’t know what else to check !!!
Received 1,189 Likes
on
How many miles? Timing chain and gears, low compression, vacuum leak, maybe try changing gas stations or low fuel pressure (bad pump).
I guess, if l did all of the work you've done with no improvement...my next step would be...throwing a vacuum gauge on it...this will tell you the quailty of the engine. Then check compression and/or exhaust manifold at each cylinder when hot at idle, with IR gun, to see if you have an unusually low output cylinder(s).
Also, are you sure your check engine/service engine soon light works? Does it come on when you first turn the key to the second position?
Brian.
Brian.
Brian.
Brian.
