Rover Has the Lean.... OME springs
Old Feb 16, 2010 | 06:39 PM
Ericshere03's Avatar
Default Rover Has the Lean.... OME springs
Ok, one thing i just noticed, my rover tilts over a bit... I have OME 779 Front Springs and unknown Rears.... However, I have one spring that says "OME 779 L/H" And the Other "OME 779 B"... L/H to Me seems like left side AKA: Driver, and B I Read Means passanger? is there a reason the labels are inconsistant (ARB wont answer). I am just worried because the truck sits an 3/4 of an inch higher on the Passanger side... It looks funny...
Any Ideas, should i swap the rears? (from left to right)
Old Feb 16, 2010 | 06:56 PM
lipadj46's Avatar
The ones I have seen are marked A for drivers and B for passenger side. The driver's side is supposed to be a bit higher.
Old Feb 16, 2010 | 07:01 PM
Thats what I keep reading, thats why I am suprised to see the Passanger Higher... Aside from the mismatched tags on the springs they seem to be properly installed... perhaps ill swap the rears since i do not know what they are (no tags)... i just dont want to mess things up more...
Old Feb 17, 2010 | 09:44 AM
Measure and tell us how low the left side is, this may help us help you?
If the rears were never changed, they can cause one side to lean.
Old Feb 17, 2010 | 10:48 AM
To clarify, Measure the distance from weel center to the bottom of the wheel arch... on the left side? I'll Just Knab all 4 sides.
I KNOW the rears are not stock, the front is lifted a couple inches and the rear is a even taller, my truck has a slight rake to it...
Ill get thoes measurements after work, tonight.
Thanks,
Old Feb 17, 2010 | 06:47 PM
Ok, The measurements are as follows. I recorded distance between wheel center to arch and distance from wheel arch to wheel center... Figures are in inches.
Drivers Front: 34.25 / 19.75
Passanger Front : 35.00 / 20.5
Delta: 3/4"
Drivers Rear: 34.25 / 20.00
Passanger rear: 35.25 / 21.00
Delta: 1"
I can understand it being a bit off BUT AN INCH, and when i plop my ***, its prolly 1.25, JK...... I HOPE, lol
Old Feb 18, 2010 | 12:49 PM
Does that fact the "Driver" in the australian lnguage actually means "Passanger" Here in the US make a difference on the spring labels, in otherwards, driver spring goes on US drivers side still?...
Old Feb 18, 2010 | 12:57 PM
lipadj46's Avatar
Your springs should be labelled for US sale. If you are feeling industrious switch them around as they obviously settled funky.
Old Feb 22, 2010 | 06:41 PM
Anyone, any timesaving ideas, or do i just start flipping around and see what happens? I just dont know weather i should swap the fronts or the rears...
JPSpen
Jan 24, 2017 09:03 PM
Spencerfitch
Apr 27, 2010 06:03 PM
Chrisinhouston
Feb 5, 2009 02:27 PM
newBrover
Mar 24, 2007 07:11 PM
