Rover will not shift out of park
Old Aug 22, 2006 | 02:14 PM
dmonares's Avatar
Default RE: Rover will not shift out of park
I bought one last friday after reading a similar thread and just threw it in my glovebox.
Old Aug 22, 2006 | 02:37 PM
geoman's Avatar
Marlymarl,
The door lock problem is most likely due to a failed--or out of adjustment--actuator. These are electrical/mechanical solenoids on each door. You can still lock it manually because you are simply moving the linkage with the button--to the lock position--something the actuator does when energized by the fob or central lock switch. You must remove the door panel to service this item. SOMETIMES you can get away with loosening the fastening bolts and slightly re-positioning the actuator to get a little more life out of it. Most of the time it needs replacing. Read my info at http://www.eurotekapg.com/bdm.html regarding panel removal. I have the part available and in stock if you decide to move forward.
Regards,
Mike McLaughlin
www.eurotekapg.com
Old Aug 23, 2006 | 02:35 PM
marlymarl's Avatar
HI Geoman,
How much is the part?
Old Aug 23, 2006 | 03:22 PM
geoman's Avatar
Marlymarl,
The actuator and door latch is a integrated assembly for the DiscoII. Our price on the part is $150.25 plus shipping at a weight of 3 lbs.
Thanks for your inquiry,
Mike McLaughlin
www.eurotekapg.com
moody
Jun 16, 2011 06:13 AM
charliesdiscovery
Jun 6, 2008 02:39 PM
johnny
Aug 29, 2007 08:26 PM
disco12
Feb 16, 2006 10:56 AM
Cirrus
Jul 27, 2005 10:51 PM
