RPM's Bounce, Then Stall
Old Sep 17, 2020 | 07:29 AM
CollieRover's Avatar
Default RPM's Bounce, Then Stall
On my way to work yesterday the rpm's started to bounce a few blocks from home. From 800 to1200 without me pushing the pedal, then it stalled. The SES light came on, but no codes were thrown. I restarted and it was fine after that, and again coming home.
I don't think it is the CPA as I have battled that and it never acted like this.
What do you guys think? Maybe the idle air control valve sticking
Old Sep 17, 2020 | 08:40 AM
Best4x4's Avatar
I'd certainly check the IAC as they can get pretty nasty.
Old Sep 17, 2020 | 10:18 PM
skucera's Avatar
No codes at all? How soon after starting up did this flame-out occur? I ask because I've seen two different causes on other German and Swedish cars with Bosch Motronic that resulted in behavior like this:
1. The battery may be tired, and the voltage droops after starting the car. This resulted in my Saab and my BMW having rough running for up to a minute after starting, but the rough running started about two minutes after startup. I diagnosed this problem with a battery tester. Voltage was dropping below 9V, and the Motronic was browning out, losing its mind. I had a similar problem like this on an old Contour, but it recorded lots of codes and made the problem a snap to diagnose a bad battery.
2. After high revs during acceleration, a worn fuel pump in my BMW couldn't feed the injectors so just as I reached highway speed the car would run very rough until the fuel pump gradually rebuilt fuel pressure, and the fuel pressure regulators (two of them on my V-12) closed with higher vacuum. Since this car was before the age of OBD, I had to rig up a pressure gauge on one of the fuel rails and watch as I did full-throttle acceleration. Our Discos should throw codes in this case that should make it obvious of the fuel pumps aren't generating enough pressure.
Anyway, those are a couple of testable hypotheses, and maybe my ideas will inspire some things for you to check that I didn't think of. Good luck.
Scott
Old Sep 18, 2020 | 07:17 AM
ReconDoc83's Avatar
my Idle Air Control Module started causing that soon after I bought mine; I ordered a new one. When I went to replace it I found out that the lock tabs on the plug were broken and it had vibrated free from the connector. Plugged it back in tight and it stopped.
so now I have a spare for future issues....
hope that information helps.
Doc
Old Sep 18, 2020 | 08:40 PM
Thanks guys. It did throw a P1834 Code which is a transmission fault.
I cleaned up the battery terminals took a small test drive and so far so good. Will test again tomorrow.
Old Sep 20, 2020 | 06:55 PM
RPM's bounced a little today when it was cold. Did not stall. Once warm it ran perfectly fine.
A little puzzled.
Old Sep 21, 2020 | 08:19 AM
JUKE179r's Avatar
From my experience the only time I had the engine rev up for no apparent reason in traffic (luckily I had my foot on the brake) was due to a bad new Duralast Cpk sensor. I really couldn't explain why the engine reved up. The Cpk sensor was the only part I had changed on my engine after the older Cpk died and left me stranded in Atlanta traffic.
I returned the new Cpk back to Auto Zone, got a Bosch from online, installed it and no more surges. Weird...
Old Sep 22, 2020 | 07:22 AM
I am going to charge the battery this weekend, and if that doesn't solve it I will likely order a new CPS. I leak oil back there and it could be fouling it.
KGN96discoSE7
Sep 23, 2017 07:23 AM
Tony C
Nov 7, 2016 01:05 PM
cobbcj7
Mar 14, 2012 04:12 PM
vtrange
Feb 8, 2007 02:26 PM
