RRC brush guard on D1?
does anyone know if the brush guard from a Range Rover Classic can be fitted to a Discovery?
some other things are interchangable so i thought who knows...
[IMG]local://upfiles/4042/59C15C04479E4D05A2AE7F8F0FAF1FFC.jpg[/IMG]
its not a stupid question... just one that would be difficult to answer without prior experience or one each of the vehicles in question... or some very good measurements... i have none of these so i am of no help at all... but its not a ridiculous question...
________
ROLL A JOINT
________
ROLL A JOINT
Well, the wheel base on the 2 trucks is the same, so I'm assuming the frame must be at least pretty similar in length of the frame. Honestly, I'm not 100% sure. Hell, I'm not even 70% sure, but if you ask me I think it should work out. Maybe a little modification required to the mounting of the brush guard via a nice big hammer.
that's what i thought... i feel like the mounting points may not be the same but they might be close. perhaps a bracket or something.
maybe i'll call Atlantic British
The biggest issue I could see with it is height, the RRC is a bit taller in the front (could look cheesy), and thenmounting points are a whole different issue that would take experience to answer. As a general rule I would say no when it comes to crossing RRC accessories and Disco accessories, but you can always work a miracle with a welder!
smokinwheels
May 25, 2021 11:11 PM
x2turbo
May 18, 2014 10:42 PM
Ruggermike
Sep 27, 2012 07:22 AM
SpeedAgent
Mar 16, 2008 11:06 PM
DiscoMikeandMike
Dec 17, 2007 01:37 PM
