RTV on valve cover gaskets?
Old 11-18-2015 | 03:30 AM
batard's Avatar
Default RTV on valve cover gaskets?
Would it be helpful to use a small bead of RTV on the valve cover gaskets? I know this generally isn't advised, but could it help delay the inevitable leaking?
Old 11-18-2015 | 06:22 AM
coors's Avatar
Yup, I use a little dab - works great. Don't over torque when reinstalling the bolts. I think 5 ft/lbs?
Old 11-18-2015 | 06:36 AM
batard's Avatar
I should use a bead of it all around vs. dabs here and there, right? And yeah, the torque spec on the bolts is super-light.
Old 11-18-2015 | 07:31 AM
drowssap's Avatar
thin coat on the whole gasket
Old 11-18-2015 | 02:10 PM
batard's Avatar
Thanks! I'm hoping they'll hold up well this time.
Old 11-18-2015 | 03:15 PM
ZGPhoto's Avatar
You're not supposed to reuse those bolts by the way...may be why it's leaking again. 6lbft
Old 11-18-2015 | 03:25 PM
coors's Avatar
Whether you reuse existing bolts or install new ones - squeeze a little low strength locktite on threads...
Old 11-18-2015 | 06:23 PM
jfall's Avatar
Permatex Aviation gasket is all I would use on those.
Make sure they are clean and dry.
Only hand tighten the bolts or they snap.
Old 11-18-2015 | 08:39 PM
Alex_M's Avatar
The valve cover bolts are stretch bolts?
Looks like I just figured out why my valve covers leak after my HG job.
How strange, I never would've guessed such a small low torque bolt would be a stretch bolt.
Old 11-19-2015 | 06:38 AM
drowssap's Avatar
come on you should know by now, every fastener is a throw away on land rover. How else can the dealers pad every bill
Quick Reply: RTV on valve cover gaskets?
