Rubber coupling or Custom TW's
Old Jun 13, 2009 | 09:20 PM
Torancis_LR's Avatar
Default Rubber coupling or Custom TW's
What is the difference between the two?
http://www.roverparts.com/Parts/TVF100010G.cfm
http://www.roverparts.com/Parts/TVF100010.cfm
The second one certainly costs less.
Or a better idea to order a rear shaft from TW with the 4 bolt conversion. With the weather in Chicago, bitter cold to burning hot-- the rubber seems not to last long.
I have confirmations that people changed theirs once every year. So in 4 years, thats 400 dollars you could invest in TW and forget about it.
What are you running on? Rubber or metal?
Old Jun 14, 2009 | 07:43 AM
Well the only difference between the two rubber couplers is that one says Land Rover and the other one does not.
Is the name worth the extra $20? No.
Mine has a u-joint at the rear diff. It was that way when I bought it.
http://www.roverparts.com/Parts/9300.cfm
Not sure if this will fit a DII also or not, its says its for a DI but I dont know for 100% if that is true.
Old Jun 14, 2009 | 08:10 AM
hazletbassist89's Avatar
I'm getting a Tom Woods to replace my rear shaft with the rotoflex, but that's not coming till I'm lifted a good 5" or so.
Old Jun 14, 2009 | 08:48 AM
A rotoflex will last from 80,000 to 100,000 miles before needing to be replaced. Rover connection has a better price on both.
The after market unit they sell is good, don't buy one from the local auto parts store, they are cheap and do fail frequently.
Make sure when installing either that you point the directional arrow in the right direction and don't waste your money replacing the drive shaft.
Old Jun 15, 2009 | 06:03 AM
antichrist's Avatar
AB doesn't say who make the cheaper one. If it's Britpart, stay away from it. Lot's of reports of the Britpart coupler shredding, and a lot of people complaining about a serious decline in quality of Britpart stuff.
Old Jun 15, 2009 | 01:15 PM
Just ordered one from Rover Connection.
Antichrist, how can you tell its it from Britpart?
Old Jun 15, 2009 | 01:30 PM
antichrist's Avatar
Ask them.
Old Jun 15, 2009 | 02:55 PM
Ask them.
Good one
thestimes
Apr 15, 2015 06:19 PM
bradical
Oct 18, 2011 11:44 PM
wendydenny27@hotmail.co.uk
Aug 26, 2011 09:06 PM
fasterdammit
May 9, 2007 09:26 AM
ScottM
Dec 26, 2006 07:14 PM
