Rubber Grommet Plugs in oil Pan/Bellhousing
Part number ERR7229. I haven't found anyone online in the US that shows it, but they can probably order it at most of the places... certainly roversnorth could get it or if you have a local dealer, you can see how much they charge.
Britcar (UK) Ltd > ERR7229 GROMMET, SUMP V8 DISC II (G)
Not to hijack your thread, but can you run around without these installed?
I will probably never do any sort of off-roading as this is a DD for me. I'm just wondering with winter coming and the flywheel being exposed to the elements will it cause any issues with the sensor or anything else?
After my rebuild I was able to get the passenger side plug back in but the driver plug is difficult due to the trans lines running right there.
So, can I leave it out or should I continue to fight on to get it in there?
