Rubber Grommet Plugs in oil Pan/Bellhousing
Old Sep 23, 2012 | 03:46 PM
Jared9220's Avatar
Default Rubber Grommet Plugs in oil Pan/Bellhousing
I'm leaving this forum and have deleted all my work in this thread.
Old Sep 23, 2012 | 05:38 PM
You are fine.
Old Sep 24, 2012 | 07:56 AM
drowssap's Avatar
you might see if you can find rubber freeze plugs in that size. yes, rubber freeze plugs they tighten up with one nut in the middle.
Old Sep 24, 2012 | 08:54 AM
jafir's Avatar
Part number ERR7229. I haven't found anyone online in the US that shows it, but they can probably order it at most of the places... certainly roversnorth could get it or if you have a local dealer, you can see how much they charge.
Britcar (UK) Ltd > ERR7229 GROMMET, SUMP V8 DISC II (G)
Old Sep 24, 2012 | 11:21 AM
Thekid's Avatar
Not to hijack your thread, but can you run around without these installed?
I will probably never do any sort of off-roading as this is a DD for me. I'm just wondering with winter coming and the flywheel being exposed to the elements will it cause any issues with the sensor or anything else?
After my rebuild I was able to get the passenger side plug back in but the driver plug is difficult due to the trans lines running right there.
So, can I leave it out or should I continue to fight on to get it in there?
Old Sep 25, 2012 | 08:40 AM
Thekid's Avatar
Buehler?
Old Sep 25, 2012 | 08:45 AM
drowssap's Avatar
no problem, when you start it up and the bellhousing is filled with frozen Ice and snow the flywheel will just grind it up. It might even come out the other hole as a 40w snow cone.
oilspotLR
Oct 30, 2015 03:47 PM
tdmadlem
May 21, 2015 06:09 AM
buick215
Jun 17, 2011 08:50 PM
B.Young
Apr 14, 2011 10:13 AM
Darover
Nov 1, 2007 07:05 PM
