Rubbing Noise in Steering
Old Dec 10, 2012 | 09:59 AM
invalidusername's Avatar
Default Rubbing Noise in Steering
Sometimes when I turn my wheel it makes a rubbing groaning noise. Sort of like dragging some heavy dry object over a rubber mat.
Then if I try to do it again it'll go away.
This usually happens when I turn it almost all the way to one side and return it to the center.
Steering seems fine but I hate that noise. Any ideas?
Old Dec 10, 2012 | 10:07 AM
How many miles on the truck, when was the p/s system totally flushed?
Old Dec 10, 2012 | 11:41 PM
144k and no idea when power steering was flushed.
Just bought a couple of weeks ago.
Old Dec 11, 2012 | 07:33 AM
Go to the top of this section and find my major service list, better plan on doing it all.
As for the steering I would start with a p/s flush, 4 quarts of p/s fluid and a small hand pump for the fluid and send me your number for directions.
Old Dec 11, 2012 | 11:27 PM
It just got a whole engine reseal including head gaskets so most of the stuff on that list is done.
PMing you
Old Jan 28, 2014 | 06:40 PM
mbonthenet's Avatar
Default Rubbing Sound any solutions?
Looks like I am having a similar issue. I am away from home, truck drove fine all day yesterday, but I arrived in my very cold destination, parked all night and this AM at 5* I started the engine and heard a rubbing sound. No matter how slightly I turn the wheel, I hear a "rubber rubbing" sound, the self leveling system seems to be running every few moments. Stopped by auto store, guy says bubbles in PS tank mean it's a pump problem. (PS fluid is amber and doesn't smell burnt). It appears to me to be turning the wheels is rubbing rubber on the tire (crawled under it) It seems to get slightly better once engine warms up. (It is possible I did not have brake fully depressed when I put it in reverse this AM- immediately pulled back into parking space and drove 1 mile tonight to check it but same though temp is 9 and will not get above 19 tomorrow) I am (currently in Blacksburg.VA) 120 mountain (I-81/I-64) miles from home (Charlottesville, VA) and not sure driving it is an option. Tires are new, not elevated, Drive shaft was replaced with TW last year and there has always been a slight vibration over 70 since.
Best course of action? Thinking a rental car and repair shop are inevitable though I have a great mechanic if I can get it back to C'ville w/out catastrophe...no major tools along this trip, but have the basics...any help is appreciated...thanks ahead!
Old Jan 28, 2014 | 07:00 PM
OffroadFrance's Avatar
Just a tip, never hold the steering against full lock in either direction at any time. Given time, it ruins the power steering pump and box. I think it even says that somewhere in the manual. I'm surprised really as most PAS has a pressure relief valve that should activate on full lock.
rover1998le
Aug 10, 2011 07:25 PM
cbloomers
Aug 28, 2010 09:38 AM
VikingDiesel
May 15, 2009 11:57 AM
robbie1400
Mar 26, 2008 03:56 AM
robbie1400
Freelander
Mar 25, 2008 09:38 AM
