Sponsored by: CARiD
Rubbing / squeaking noise
Old Mar 25, 2008 | 09:39 AM
robbie1400's Avatar
3rd Gear
Default Rubbing / squeaking noise
I have a 1999 1.8 Freelander which I am very happy with. However, recently it has developed a strange noise. It only affects the car after it has been driven for 10 minutes or more (ie when the fluids have warmed up). It is a speed-related squeaking noise. It starts at around 20mph and rises in frequency with the road speed. Putting the car into neutral or changing gear makes no difference to the noise. As I slow down the noise stops once I get below 5mph.
The noise is most noticeable outside the car - ie when you have the windows open. With the windows shut, it is hardly noticeable.
The car has 60k miles on the clock and has been regularly serviced by a LR agent.
Any ideas?
Old Mar 25, 2008 | 12:50 PM
WolfPack's Avatar
Default RE: Rubbing / squeaking noise
Does it squeak when you turn to one side more than the other? If engine speed does not affect the squeak, you're probably looking at hub/bearing/wheel.
Old Mar 26, 2008 | 03:56 AM
robbie1400's Avatar
3rd Gear
No - the noise appears to be coming from underneath rather than any specific side and does not seem to be affected by turning the wheel.
I figured it might be a bearing but the fact that it is so speed-specific (on at 20mph and off at 5mph) makes me wonder if it is something more sinister....
I'll get the bearings checked. Thanks for taking the time to respond.
invalidusername
Jan 28, 2014 07:00 PM
rover1998le
Aug 10, 2011 07:25 PM
cbloomers
Aug 28, 2010 09:38 AM
VikingDiesel
May 15, 2009 11:57 AM
robbie1400
Freelander
Mar 25, 2008 09:38 AM
