rubbing noise when i turn wheel to the right at crawl speeds
Old May 13, 2009 | 09:22 PM
VikingDiesel's Avatar
Default rubbing noise when i turn wheel to the right at crawl speeds
so if im backing out of a driveway and begin to turn my steering wheel to the right, it will make a rubbing noise but now the whole way turning. Example: Im slowly turning the wheel to the right and as im turning it, ... turn..... RUB......turn....... RUB.... and it ONLY happens when i turn to the right... any ideas,
Old May 14, 2009 | 09:07 AM
What year Disco, what size tire, how many miles on it and is it lifted, all these things matter.
Old May 14, 2009 | 10:56 AM
hazletbassist89's Avatar
Go jump under your truck with wheels at full turn and see if you can see where they are or would possibly make contact with anything in the wheel well.
Old May 15, 2009 | 11:30 AM
99 DISCO II, STOCK EVERYTHING, 120k miles
Old May 15, 2009 | 11:57 AM
So, as already mentioned, crawl under your truck and look at the front radius arms for tire wear.
ellebarto
Sights N Sounds
May 27, 2013 01:30 AM
Mojigglins
Apr 22, 2013 05:58 PM
bigmac
Dec 2, 2008 10:21 PM
klh113
Sep 18, 2007 10:34 AM
