Running Hot
Old Mar 23, 2009 | 07:09 PM
TheQ's Avatar
7th Gear
Default Running Hot
On my home tonight I noticed my '02 Disco was running hot. Low coolant and the driver side front axle is soaked. I can't tell where it's leaking. Anyone have any ideas before I get under it tomorrow morning?
Old Mar 23, 2009 | 07:21 PM
Throttle body heater plate is the first place I'd look.
Old Mar 23, 2009 | 07:27 PM
TheQ's Avatar
7th Gear
Where exactly is that? Is that something that can be done in the driveway or am I looking at a big bill?
Old Mar 23, 2009 | 07:42 PM
http://roverparts.com/Parts/ERR6623.cfm
That is the part that you would need IF that is the problem
In your driveway, 15 min.
Look for the two coolant lines going to the throttle body and look for the leak there.
You can buy that part at your dealer for around $5.
Old Mar 24, 2009 | 10:05 AM
If you are not sure what to look for, fill the coolant bottle, when the engine is stane cold, to the top of the cap, make an appointment with a shop to have the system pressure tested and repaired. You do not want to allow the engine to over heat again, they are expensive to replace.
Pik
Mar 27, 2013 08:00 PM
94svt50
Jul 8, 2012 03:31 PM
LRScott
13
Apr 7, 2010 02:26 AM
twmj1953
Sep 29, 2009 09:49 PM
dgstringfield
Jul 12, 2006 12:17 AM
