Running hot
Old Feb 22, 2014 | 02:26 PM
mikep70's Avatar
6th Gear
Default Running hot
I have a 2001 Discovery SEII and I recently replaced the water pump and thermostat because of the car running hot. After replacing the parts, the car is still running hot. The heat also will not work get hot unless I'm driving and the car runs hot. Didn't find any leaks and everything looks good. Any ideas??
Old Feb 22, 2014 | 02:29 PM
dusty1's Avatar
Air in the system? Do you hear slosh waterfall sound in the heater core? Search and follow proper bleed procedure... Bleed and bleed again
Old Feb 22, 2014 | 05:44 PM
earlyrover's Avatar
" Running hot"
Best advice is to NOT. Rover Engine you destroy may be your own!
Old Feb 22, 2014 | 06:43 PM
FreeRideSLR's Avatar
I had the same issue until I replaced the TB heater, flushed the heater core, replaced the rad, and installed a 180* stat. Fixed everything.
Pik
Mar 27, 2013 08:00 PM
94svt50
Jul 8, 2012 03:31 PM
LRScott
13
Apr 7, 2010 02:26 AM
twmj1953
Sep 29, 2009 09:49 PM
dgstringfield
Jul 12, 2006 12:17 AM
