Running Hot
Old Jan 2, 2019 | 04:58 PM
redwhitekat's Avatar
I’m going to try it tomorrow I have some insulation foam tape
Old Jan 2, 2019 | 05:19 PM
Extinct's Avatar
Do the bypass thermostat mod and you can run whatver temp your want based on the thermostat you install, much more reliable thermostat and temps. If it still runs hot you have a plugged radiator - you can pop the end tanks off and flush it and it will be all good.
Good luck
Old Jan 2, 2019 | 08:35 PM
Best4x4's Avatar
Jegs had a sweet looking inline for sale at 29.00 but it’s 1 1/2 vs 1 1/4... I really liked the design vs the usual one everyone uses.
Old Jan 3, 2019 | 07:05 PM
Extinct's Avatar
Just use the back to back Chevy housings - I like it better because you only need standard 1/2 wrench to replace it. My buddy did his Dad's and the new housings were only $12 from Advance.
Old Jan 8, 2019 | 07:51 AM
FlyingZebra34's Avatar
Finally had time to get back to my Landy. Viscous clutch on the fan was crapping out. Swapped it out and it seems to have fixed my issue.
I had another D2 awhile ago that I did full electric fans with an aluminum radiator. Worked really well when I was working in the desert. Nothing like a 130 degree day to bring out a Rover's weakness.
Rlozano
Jan 4, 2017 03:38 PM
Dan7
May 21, 2013 09:00 AM
Phoenix_522
Nov 28, 2012 10:37 AM
LRScott
Sep 25, 2011 08:19 AM
UpChuck
Nov 14, 2010 06:10 AM
