Rust on sleeves
Old Feb 10, 2018 | 12:04 PM
lrnoob's Avatar
Default Rust on sleeves
Pulled the heads. A few of my liners have rust on them. It's surface rust only, with no pitting that I can see. What's the safest way to clean it off?
Old Feb 10, 2018 | 12:56 PM
lrnoob's Avatar
Tried wiping with oil and ATF to no avail.
Old Feb 10, 2018 | 04:38 PM
Alex_M's Avatar
On the ends or in the bore? White vinegar is a great rust remover. It has to set on it for a while though, then it will pretty much just wipe off.
Old Feb 12, 2018 | 07:16 AM
shanechevelle's Avatar
You can also try a bottle of rust remover at Walmart, its a mild acid that will wipe the rust off.
You can try a honing ball, its a tool you put in your drill and spin it inside the cylinder.
rewi9d
Apr 27, 2020 05:46 PM
mx930
Nov 7, 2010 06:39 PM
dc10freighter
Oct 18, 2009 04:05 PM
01 Discovery SD
Feb 28, 2009 10:26 PM
rphotographer
May 16, 2007 08:52 PM
