S and M Mode turn off by it self while driving
Hello all,
I need a help with my D2 2004 automatic transmission switch when selecting S and M Mode.
while driving when i select S mode on the Gear and M in Low Gear .. it works fine for a while then it turn it self off ..
i don't know if the problem related to the Electronic automatic transmission ECU or the Engine control module ECM or maybe something else that i can't relate to ..
i would appreciate any help from anyone who had the same problem and managed to fix it .
thank you
thank you
Hello all,
thank you
thank you
i had had this happen last summer on my 03
not sure what happen or if there was any tranny codes but it went away on its own
Just to keep following the same problem.
After covid 19 lockdown my battery died for a week or so, jump started it but it was dead.
replaced it with a new one
12v
cold cranking amps 730
cranking amps 860
amp hours @20 hr rate 90
i also checked the connector for the s mode and it cleaned it
the problem is still there. When I press S mode while in low rage to get M mode it keeps working for 60 seconds and it turn it self off by it self
I need to shift manually
anyone might know what is going on ?
12v
cranking amps 860
