Sagging headliner
#51
It can be 'très difficile' AR. It really depends on the quality of the new headliner material sandwich and the prep of the grp backing. The spray adhesive is critical and I've used 3M's glue, not cheap but good glue. It's best to do the fitting in 2 halves not attemp it in one mad panic. Lay out the material on the grp backing to ensure it's central allround with it pushed roughly into shape then fold back the half you are going to stick down. Ensure you have good quality tools, craft knives, scissors, rubber and wood/plastic seam rollers, ball shaped rollers but most of all ensure they are all spotlessly clean. Make sure you have the adhesive remover for any errors or clean ups and also have a supply of medical type latex gloves which are better for grip and keeping everything clean. Have fun
#52
#53
I give up on installing this fabric. Ripped everything off. Sometimes it's best to just pay the pro's. Ordering 3 more yards and will take it someplace.
On a positive note during the time I thought the glue was tacking I replaced my passenger window motor so that's good haha
#54
Taking the headliner out was easy. Putting it back in will be just as easy. It's gluing this foam backed material proving to be difficult. If I had used a regular piece of cloth or painted it I would be done by now.
I have inspected my drain tubes and no problems with them. I also installed 04 roof rails since I had the liner out.
#55
"Ya gots to know your limitations" I have done a few headliners and I was never satisfied with the end results. I don't fit in some of those tight spots. I think I will leave the new liner installation to the pros on this truck. Looks too nice otherwise.
My other projects I didn't really care too much about them and I sprayed some glue up in there only to have it let go a few weeks later. So out came the Straight pins (not a good choice either) I like the idea of the upholstery pins.
I believe I have an aftermarket sunroof that doesn't open. I think to fix it, I need to have the glass open. Not too sure how that is going to work yet...
#56
#58
#59
#60
Guys, guys, guys. For the gazillionth time, just strip off the old fabric and foam and adhesive and paint the headliner. Denatured alcohol strips it clean and the fiberglass shell has a wonderful pebbled finish for the paint. Prime it with kills and then use two coats of a good exterior latex.I painted mine several years ago and it still looks perfect. And it will never, ever sag again.
